the current peices i have are a KB hyper pistons with 6cc valvle reliefs, forged i beam rods, JE rings, eagle crankshaft(4340), clevite 77 bearings, fel-pro gasket, AFR 205 heads, planning on using a weiand stealth series manifold so i can have more torque down low. and thinking about comp cams 280HR not sure on how to choose the cams though, so any suggestions would be great, and if you think this combo is good. i'm not sure about bring this upto 7k+. this is just my first engine build and would like to have a nice engine, the stall speed i was thinking in the 3000 range maybe a little higher. the title on the car says it's only 2300 pounds can't be right, it's a 79 mustang. not sure if the title was for a 4 cyl. or what so i don't have the weight, i can guess about 3000pnds or so. let me know you opinions, places for improvement, and if i'm looking at the right cam if i use the 205's
