Keane Dave Cobrashoch is pretty close on what set for your car. He left out Canton pans with crank scraper. What are you going to do with the car? Roadracing,1/4 mile drags, Autocross, Street car, Show and shine? You will need a vaccum pump if you go dry sump, plus seperation tank and hoses. Aviaid make a complete set for and 429/460 motor. You can e-mail them at
www.aviaid.com You will have info in a day or 2. I am going dry sump on my next motor. I autocross and like road racing. If you get a good pan and 3 quart acusump you may not want to spend 3 grand for this option. A 9 quart oilpan and 3 quart acusump may be all you need. You can also use the acusump as a preoiler before you start the motor. Stops dry starts. Saves bearings. You might want to buy a better
oil pump. Titan uses a georotor gear instead of spur gears. The inlet to the pump is twice the size of any other
oil pump and has a regulator for pressure control on it. Something to look into. Good luck Rick Lake
