Thanks, yeah I haven't taken the block to the shop yet. But I'm doing the min bore necessary to clean up the walls (whatever they tell me that is).
Any recommendations as to piston types I can start to research (brands, etc.?). This is going to be a streetable, moderate output engine. I want 350hp NA. I'll be using the stock crank and con rods. Don't think I need anything fancy in the piston department. Can you recommend any decent ones? Or should I just go to Ford and get 30-over OE replacements or whatever?
