Old 07-11-2004, 06:02 PM
Bruce Edwards's Avatar
Bruce Edwards Bruce Edwards is offline
Cobra Make, Engine: Hunter with a 4.6 supercharged
Get a nice set of sealed power hypereutectice, may not be the correct spelling sorry, pistons. They run cooler are stronger than standard cast pistons and will perform well to the HP you want to run. Set them up with a set of moly rings, top groove only, also by Sealer Power.
Do not forget to grind the crank, resize the rods (install new rod bolts) and have the heads redone or install a set of aluminum ones.
Bruce Edwards
Gemini Motorcars Inc.
http://home.bellsouth.net/p/PWP-GeminiMotorcars
