Vic,
Should be in the 8.5 range. Yes I would not use stock cast pistons in any engine that gets close to 1 hp per inch. They are just not that strong and the others are that much better for not much more. I do not rember the deck height sorry.
If you want to get that kind of power from the engine you will need to raise the compression.
Bruce Edwards
Gemini Motorcars Inc.
http://home.bellsouth.net/p/PWP-GeminiMotorcars
