Thread: Brake Bleeding
  #28 (permalink)
Old 07-12-2004, 06:43 AM
rdorman's Avatar
rdorman rdorman is offline
Renegade Nuns on Wheels
Dominik, I don't think it depends on caliper. I always bleed the inner bleeder first and the outer last.
All, Yep, always a good idea to bleed front and rear at the same time.
I use a jar and a tube placing them so that the bleeder is always covered in fluid and just pump away! Also be sure to only open the bleeder enough to let the fluid out, to much will draw air in around the threads.
Bob, no problem! Happens to me all the time! I took one premade line and cut it in half that way I can bleed both at the same time.
Rick
OhioCobraClub.com
LondonCobraShow.com
