Originally posted by CSX 4027
Please understand that the wire is an indicator as opposed to a definitive for keeping the spinner on. The wires should not be set completely tight but rather with a bit of slack so if the spinner backs off it will actually then tighten the safety wire. This will give you the indicator that you need to know that there is movement.
Understood. I already planned to build a slight "loop" into the strand that would help me indicate a loosening situation.
I was just thinking that a thicker wire is more durable and less forgiving.
