Old 07-13-2004, 08:24 PM
Curt C.'s Avatar
Curt C. Curt C. is offline
Cobra Make, Engine: Classic Roadster; 351W
I have mine mounted on the driver side inner fender. You want to try and keep it relatively close. Too long of a coil wire can result in issues. Can you mount it behind the engine somewhere and run the wire along the intake manifold? If you were running a vic. jr or air gap, you could run it through the air gap. That looks pretty trick.
