Aluminum Heads and Intake questions
I know many of the engine builders here do quite a bit of porting and such but for off the shelf heads for an FE motor who's are the best?? Why?
How do they compare?? Edelbrock, Shelby, Dove, others???
Which intake would you pick to go with them for a single 4 barrel that will still fit under the hood of a Kirkham?
I found a good deal on a running 428 that has iron heads on it now for the car I have on order. The guy has the build sheet on it and it's only bored .015 over has 10.5:1 pistons and a decent cam in it. If I buy it I want to switch to aluminum heads/intake and water pump.
Scott
