J.P.
I've changed to the Jordan shifter and I've actually had to take a drill bit to the top bolt hole and elongate it ever so slightly to make the Jordan fit (it was off maybe a millimeter at the most). I was careful and took my time (several passes and refits) so that I maintained a snug final fit. Some lock-tite on the two bolts and it won't go anywhere. I have not aligned the stock shifter yet (it's hanging on my pegboard). Maybe later tonight I'll check into it for you and determine if that too needs a little massaging to fit.
-Deano
