Dan;
The rod bolts are pressed in and what the machine shop will do is put the rod cap end on a sander and slightly sand the end down to get it perfectly flat,then they bolt the cap on the rod to specs and check the bore diameter...... It will be a little "small",then they put the rod end on a fixture and it is similar to honing a cylinder bore,they hone the inside to get it back to factory specs.......I can't remember what I was charged for this,it has been almost 10 years now,but not that expensive and very worth while......money well spent........
David
DAVID GAGNARD
