Old 07-17-2004, 03:48 PM
Randy Rosenberg Randy Rosenberg is offline
Cobra Make, Engine: SPF #1019
Thumbs up For Sale - 2001 Superformance #1019
NO LONGER FOR SALE ! ! !
For Sale: 2001 Superformance “1965 Shelby Cobra” Replica # 1019
Up for sale is fully sorted out, reliable Superformance Cobra Replica with 7800 miles. The drive train is a Ford Motorsports 460 (535HP) with Tremec TKO 5 speed transmission, and with the standard 3.73 Independent Rear Suspension.
[links below open into new windows]
Exterior:
Guardsman Blue with Wimbledon White Stripes.
Chromed Side Pipes with Ceramic coated headers.
Chromed Driver and Passenger Roll Bars.
Chromed Bumper Uprights.
Custom Aluminum Transmission Tunnel Heat Shield.
Frame Mounted Trailer Tie-Down Loops.
Custom Aluminum Radiator Bug Guard.
Custom Polished Aluminum Windshield Wiper Covers.
3M “clear” Guards on Rear Fenders.
Optional/Removable Static Cling vintage meatballs and stickers.
Tonneau Cover, Convertible Top and Side Curtains.
California “Plush Weave” Car Cover.
California “Interior” Car Cover.
Numerous coats of Zaino lovingly applied.
Interior:
5 point Deist Harnesses for both Driver and Passenger.
Custom “snap in” Floor Mats.
Safecraft 3lb Polished Aluminum Halon Fire Extinguisher.
Safecraft 5lb “in-car” Halon Fire Suppression System.
Both Moto-Lita Black Leather and Wooden Steering Wheels.
Custom Olthoff Padded Driver Side Knee Pad.
Hidden 12v Power Port.
Wilwood Brake Bias (cockpit mounted).
Battery Disconnect Key (cockpit mounted).
Optima 75/35-925 Battery (trunk mounted).
Engine and Oil & Fuel Systems:
Ford Motorsports 460 (535HP).
Blue Thunder Dual Plane Intake.
Holley 750HP – Double Pumper – Mechanical Secondaries
MSD Billet Distributor and 6AL Ignition/Blaster Coil.
Blue Ford Motorsports 9mm Spark Plug Wires with Custom Wire Looms.
Blue Thunder “Cobra” 2 piece Value Covers.
Polished Turkey Pan and Stellings & Hellings Air Cleaner with K&N Filter.
Aviaid Oil Pan with Custom added Channels for Improved Oil Pickup.
Large “Racing Style” Fram HP6 Remote Oil Filter.
3 Quart Accusump Pressurized Pre-Oiling System.
Peterson Oil Breaker Tank (Puke Tank).
All Braided Steel Oil Lines.
Polished Aluminum Clutch Reservoir and Power Brake line.
Polished Aluminum Ford SVO Pulleys.
Fuelsafe Fuel Cell with Carter Electric Fuel Pump and Peterson Fuel Filter.
Polished Aluminum Radiator Overflow Tank.
Drive Train, Brakes, Suspension, Tires and Wheels:
Tremec TKO 5-Speed Transmission.
McLeod Aluminum Flywheel, Clutch and Pressure Plate.
Koni Dual Adjustable “Custom Valued” Coil-Over Shocks with 300lb Springs.
Upgraded 15/16” Rear Anti-Sway Bar.
Polyurethane Anti-Sway Bar Bushings.
Wilwood Dynalite Calipers with Bridge Bolts.
Teflon Coated Braided Steel Brake Lines.
Wilwood “cockpit mounted” Brake Bias.
Trigo Halibrand Replica Wheels with Polished Stainless Steel Knock-Off Spinners:
- Front: 7.5” x 15” with Goodyear GTII 235/60-15 Tires
- Rear: 9.5” x 15” with Goodyear GTII 275/60-15 Tires
Custom Foam “under fender” Lining.
Finished by Top of the Hill Performance Center, to build this Superformance today would cost over $80,000. It has never been driven in the rain, and always garaged (and covered) when not in use. This Superformance runs well on Premium Pump gas.
Asking Price: $60,000 - equivalent trades welcome/encouraged - serious offers welcome, too!
Included are: extra HP6 Oil Filters, Tan and Black Brake Pads.
Please note that this Superformance is not legal for title in California.
