It goes on the passenger side. Either high or low mounting, depending on the brackets.
On the lower mount version, the brackets mount to a place on the water pump, and have a 3" long spacer to the block. Better check to see if the lower mount would work on your chassis.
Some of the companies specializing in 460 truck conversions sell aftermarket upper mount brackets for the 460.
6th generation Texan....
