Tom,
I will be in till 12:00 when we close for lunch. Then I have to go see my Doc at 1:30 but should be back by 2:15 or so. Wednesday is kind of crazy around my place.
When you call try to have as much info as you can as to what you have in the engine, what the car weights, and what rear end gear you are running. Also what stall speed converter you are running.
If you have any idea as to what the last builder put in the C-6 as far as HD parts to upgrade the trans. Hard parts do not normally good bad but if you are running a 351 trans behind an FE you need to get a different set of clutch drums to handle the extra load. The way Ford and most factory trans are made to handle different loads is my changing the clutch number. A small set for a small engine and more clutches for a larger engine.
Talk to you tomorrow. Again sorry I missed the fact that you are that close to me.
Bruce Edwards
Gemini Motorcars Inc.
http://home.bellsouth.net/p/PWP-GeminiMotorcars
