Old 07-22-2004, 09:40 PM
G.R.'s Avatar
G.R. G.R. is offline
Cobra Make, Engine: NAF 289 FIA, 347 stroker with Weber 48's, building a '48 Anglia gasser, driving a '55 Chevy resto-rod
Send a message via Yahoo to G.R.
Until the engine is turned over and the MSD box is "Hot" there won't be a voltage reading at the coil. Just turning the switch on won't show voltage at the coil.
I have all MSD ignition and encountered the same--called the tech-line and they confirmed it--as long as you wired everything per direction you should be able to turn over the engine and it will fire up--you'll then have voltage at the coil.
"Breathe in... Breathe out... then move on with life. Lifes too short to sweat the small stuff"
