Old 07-23-2004, 06:41 PM
bmcmillan bmcmillan is offline
Cobra Make, Engine: B&B non-donor, 496 Genesis SO (608 HPwith 9.4:1 CR), Tremec TKO, Currier 8.8
I would have used 2.73's if the Ford Motorsports gears were available in that ratio. 2,500 RPM's is turning too fast in a BB 2,500 lb. Cobra on the highway. You need to be thinking about 1,800 RPM.
If the suspension is set up correctly, you have a serious highway cruiser with the higher gears.
For track, the FE is such a stump puller that you will actually turn better times if you don't rev it as much.
Definitely the 3.23's.
Brian
