Wanting to switch from a continuous leaking hydraulic throw out bearing to an external slave cylinder and have a couple of questions.
1. The steel scatter shield for this 4 speed toploader to 427 side oiler is of unknown origin. It has a pivot plate for the clutch arm that has a small rectangular slot in it that appears to be the pivot point for the clutch arm. I was expecting to see a pivot ball for the clutch arm to ride on but found the slotted piece of plate instead.
What type of clutch arm will fit this type of hook up?
2. Any suggestion for a slave cylinder would be appreciated. The NAF Cobra has a Tilton ( I believe) clutch master cylinder.
Thanks for any help.
