Old 07-24-2004, 08:31 AM
Ron61's Avatar
Ron61 Ron61 is offline
Post
Strick,
Your water flow should be from the pump through the top hose to the radiator, down through the radiator for coling, out the bottom hose to the pump and through the engine and back again. All of the above suggestions are good and should be checked. Also make sure that you have the correct thermostat and that it is working. Is your bypass hose connected?
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
