Mike:
I sent a private message as you suggested. I also wanted to anwer your questions from a previous message.
The cover is the same length as the SPF tonneau cover, although the SPF cover is about 2" wider on the rear corners of each side. Hope this helps. The cover is vinyl. I bought the EM Cobra assembled and used, so I don't know if the cover is a EM production product.
I also wanted to ask you about your car. I also have rear exhaust. Did you have the headers custom made or did you buy them? The SPF headers are a small diameter and somewhat restricted. I would like to replace them.
Are your exhaust tips stainless and if so where did you buy them? I have found stainless exhaust tips but only in 3+ inch diameter. I want 2 1/2.
Thanks,
Tom
