Old 07-27-2004, 06:01 PM
Karl Bebout's Avatar
Karl Bebout Karl Bebout is offline
itBites and Myles, thanks for the input. I knew the Dominator has a bigger base but King Cobra mentioned an adapter plate that I thought might work. Was just wondering if it would fit under my hood. Myles, your thought about the bottom end is probably absolutely right. I used the CFM calculation to determine if the Edelbrock 800 would be sufficient and found it to be very adequate. Just thinking that maybe I could use a bit more mixture, although I don't crank it beyond 6400 RPMs. I like driving more than wrenching so I try to keep the internal stuff inside where it belongs. Bulletproof so far. Knock on wood! ItBites, good to see you too. We were just talking that we hadn't seen you for a while, and up you walk. Thanks,
Karlos
