Thread: TKO Clutch fork
Old 07-28-2004, 10:39 PM
joea's Avatar
joea joea is offline
Cobra Make, Engine: ERA #676, 428SCJ (2x4), TKOII
Default TKO Clutch fork
Anyone use this clutch fork with your ERA? It is a TKO clutch fork(from David Kee). First my clutch slave was too close to the fork. Doug at ERA sold me a spacer that pushed it back and in closer to the engine. I still don't have a good fit. The fork can be pushed all the way down towards the ground and it lines up decent but when I use the pedal it creeps back up to the point it rubs a little on the fiberglass. Once it is in this position not only does it rub on the fiberglass (lower body tunnel) but then the push rod is off center and the threads grind on the slave cylinder when I use the pedal.
I think this is the last gremlin I need to solve before I can drive the car so any help is greatly appreciated.
"There are 10 types of people out there....the ones that understand binary and the zeros that don't."
