Old 07-29-2004, 08:10 PM
SleeperSupra SleeperSupra is offline
A T5 is only rated between 235 up to 310 lb/ft of maximum torque, depending on the year it was made. Even a mild 460 would chew it up in no time at all.
Just get the Tremec Ford TKO 600, it will pay for it's self in not having to rebuild it every week or two.
The Ford TKO 600 is torque rated at 600ft/lbs. 26 spline input shaft with a 31 spline output shaft. Comes in two standard over drive configurations 1) 2.87 first gear .82od and 2) 2.87 first gear with .64od. Standard shift location is the rear "Mustang" shift point. Mid and front shift kits available. Main case bolt pattern remains the "toploader" pattern.
Hope this helps.
