Old 07-29-2004, 10:29 PM
pneall's Avatar
pneall pneall is offline
Mando,
The body is supported by the 20mm ? tube at the front. This is held in place by expander foam once all is bolted down. It ends up very strong.
You will find the body much easier to get on and odd if you cut the corners at 45 degrees off rear cross rail (the one behind fuel tank) This has no impact on strength but saves your fingers and the fibreglass.
Regards,
Phil
