Rick; I've been looking for one for a while,have not found anything....
Trularin; Great,actually all I need to convert to 28 spline is the splined hub in the carrier,I have a couple of 28 spline axle gears laying around,I'd have to find them..... I call it the "hub",not sure what it is supposed to be called,but it is where the clutches go and is splined to 28 or 31 depending on the axle...if you also have the axle gears,I'd take them also,my clutch pack is like knew and I will reuse it....I also have an extra clutch pack and a few other parts as I usually do not throw away anything.........
A 28 spline axle will go into a 31 spline carrier as the 28 spline is a little smaller diameter,but 31s will not go into a 28 spline carrier for the same reason.....
Actually on my street Mustang,the trac loc unit was a 31 spline unit out of a truck that I converted to 28 spline 10 years ago when I got it....
trularin,let me know what you have and what you want for the parts..........
Thanks;
David
DAVID GAGNARD
