Dave, Looks like your in luck.
I have four drive gears, with shims, and two idlers.
As I recal, you disassemble the center section and remove the 31 spline gears and install the 28 spline gears. Then you run the pinions through and die them. check the pattern before you assemble the rest of the rear end. It's like doing the ring and pinion, only smaller.
So, send me your address and I'll get those to you.
