Old 07-31-2004, 05:09 PM
cobrashoch cobrashoch is offline
Cobra Make, Engine: Home built, supercharged 544cu/in automatic
Dan - We used the same Weiand X-celerator with no port matching done and a 750 holley on both the Aussie headed motor and the 4-barrel motor. At that time I though the intake was too much for the Aussie motor and not enough for the 4 barrel head motor. The 4 barrel heads were big chamber smog heads that had extensive work done to them by Russ at Indy cylinder head. (both expensive and good you can be sure of, with bowl work and completly polished)
cobrashock
Ron Shockley
