Old 08-01-2004, 05:50 PM
Bruce Edwards's Avatar
Bruce Edwards Bruce Edwards is offline
Cobra Make, Engine: Hunter with a 4.6 supercharged
Matt,
The lifter is in the block and rides on the cam. The valve train on most older Fords was not adjustable. You tightened the nut till it hit the built in stop on the stud. The stop is a shoulder built into the stud. That is why I asked if you had screw in or pressed studs.
Bruce Edwards
Gemini Motorcars Inc.
http://home.bellsouth.net/p/PWP-GeminiMotorcars
