Old 08-02-2004, 12:56 AM
PCC's Avatar
PCC PCC is offline
Default Ill fitting doors
Anybody got any advise on how to cure an ill fitting door.
Only a problem on rough surfaces (most of QLD roads) when it rattles on the lock plate.
Tried adjusting both the door catch and lock plate, but simply returns a few 100kms down the track.
Thought of fitting some foam or something round the latch, but would prefer a tidier solution.
My problem is a little bit harder to resolve as I have electronic door handles, which are pretty sensitive i.e. door too tight, won't open electronically.
May be I should perfect the technique the Dukes of Hazard used, thereby have the doors glued
Passenger door fine, only the driver's door - maybe I should switch the steering to lhd and at least I won't notice the problem
PCC (Peter Craig)
Keep the sun shining
