Old 08-02-2004, 04:57 AM
TonyMadrid's Avatar
TonyMadrid TonyMadrid is offline
Cobra Make, Engine: A&C 351W, C4
Default SBF Decking
Decking is always a good idea to insure an even plane surface for mating the heads to the block.
You made no mention of what size & year block you have. If you have a 351W, keep in mind that the earlier blocks had a shorter deck height to begin with, by about .020". This is important and critical to piston selection so you will have ample valve to piston clearance.
Tony
