Thread: Brake help
Old 08-03-2004, 01:30 PM
blykins blykins is offline
Earl, you just need one proportioning valve....that splits the front and rears....
You just have one master cylinder? I guess so since you're using power brakes. Anyway, you should have a line coming out of your master cylinder goin to the proportioning valve....then the valve will let you split between the front lines and the rear lines. Each line coming out of the proportioning valve will just need a tee that will allow a separate line to go to each caliper. Make sense?
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
