Found the mounts
The mounts for the SPF are part number 2287, this is 1967 convertible cross ref. But at NAPA they are 602-1152's and 7 dollars cheaper than Mustang shops. At kragan the ysaid they were galaxy mounts "go figure". The mount has been reinvented with a bolt thru the two common metal half's making the mount stronger. I researched the Olthoffs mounts and found that they are chevy energy suspension mount adapted to fit the modified pedestals of the SPF, also with a bracket to fit the block. I am going to modify the pedestals to fit the Prothane Mustang mount which will only require the pedestals to be modified, at $23.00 per for the pedestals and $110.00 for a set of Prothanes, comes in cheaper than the 200.00+ for the Olthoffs setup. The pedestals will only have to be shortened by .600 - .750 to allow for the prothanes. but for now I will run the 602-1152's from NAPA at $11.00 per side. The mount i took off was a pile of crap, the one i bought with the bolt ran thru the 2 metal piece's and thru the rubber was stronger looking. I hope this helps SPF people out
Thanks for the help fellow Cobra folks
GWC
