Old 08-05-2004, 02:21 PM
davidlee davidlee is offline
Cobra Make, Engine: sold BDR #123 351w, Tko 17" full polished wheels
I was told by Reg at Backdraft to remove the output spline protector. If it is not removed you may not be able to install the drive shaft. This problem would only occur if the drive shaft yoke had to penetrate into the tail piece deeply. I removed my spline protector with no problem and and no trouble with the drive shaft install and no oil leaks.
David
