Old 08-06-2004, 07:03 AM
Ron61's Avatar
Ron61 Ron61 is offline
Post
ED,
I am sure this was in one of the posts threads listed earlier, but my biggest problem was that they just put balance weights on the inside of the wheels. Since I run all four tires the same size I had switched the fronts to the rear and I still had the same shake around 60+. After having them balanced with the weights on both the inside and outside of the wheel most of that went away but there is still some vibration at higher speeds.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
