08-08-2004, 07:55 AM
MN
Cobra Make, Engine: Classic Roadsters; 351w, Crane Cam, AFR 185's
Still checking...
The engine is sitting higher on the right side which would account for the sidepipes needing a larger cutout (by about an inch). Do the "old" and "new" motor mounts look different from each other?
I have checked the rear portion of the body as thoroughly as possible and find NO contact with the frame whatsoever.
What the he!!?
Should I grind down the surfaces that contact the sides of the cowl bars?
