Old 08-08-2004, 10:15 AM
TC Cobra's Avatar
TC Cobra TC Cobra is offline
Cobra Make, Engine: Classic Roadsters; 351w, Crane Cam, AFR 185's
Thanks, Don!
Already fixed the hood latch bolts.
Took the spring adjuster bolts out. (waiting for coil overs ;-) )
Did trim a little around the rear of the e-brake housing but it wasn't enough to make a difference.
Got plenty of clearance in all areas of the rear section - that's the problem. No contact at all with the cross member under the package tray (~1/2") or the outriggers. The floor pans under the seats is a good 3/4" above the cross member.
I appreciate your help!
Dwain
