Old 08-08-2004, 04:31 PM
Bill E's Avatar
Bill E Bill E is offline
If you are not afraid of a little glass work cut the seat tray s loose and drop them down. Ruff the edges back 6' two lairs of 3 oz mat will do it. on the package tray one by fore inch 'Red wood will fill the gap use five 5/16 s self taping 2' screws E600 silicon adhesive will work to. You can use it any where the body touches the frame and it will eliminate creeks radials, and squeaks. Also fill the void under the doors through the rear wells whit expandable foam the minimal expanchion type, you will be amazed at how much moor solid the car will fele. The best method to do this is to attache 1/4 inch vinyl tubing to the nozzle of the crack foam can about 3 feet (Important) use a tie strap onthe nozel then tie strap the other end to a yard stick, push it in from the wheel well and start foaming as you pull it out. If you wont to install wiring later you can put some 1' PVC tubing in first. Don't trim for 24 hours.
Bill Emerson
