Old 08-09-2004, 03:22 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
mylesdw,
how exactly does the distributor's vacuum advance have any effect whatsoever on the fuel mixture? as per:
"Set up correctly vacuum advance should make no difference to the power output at any point but should allow it to run leaner and cleaner at cruise"
