Problem fixed.
There is a rod from the side of the gearbox that goes to the T-Bar, and there is a slot on this rod where it mates with the bolt from the t-bar, therefore allowing you to adjust the position.
The bolt was loose and it had slid along the rod, causing neutral and reverse to be in different positions.
Was not looking forward to a tranny strip down
Thanks Guys
