Old 08-09-2004, 03:52 PM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Assuming the cooling systdem components are working correctly, would suspect a combustion gas leak into the cooling system caused by a leak from block, head, or head gasket.
With radiator full, take radiator cap off with engine running and look for air bubbles or froth/ foam in coolant.
