Old 08-09-2004, 05:29 PM
CJ428CJ's Avatar
CJ428CJ CJ428CJ is offline
Cobra Make, Engine: ERA #629, BBM Side Oiler Block, 482ci, Richmond 5 speed
Brad,
Don't dremel out the flywheel hole. The flywheel is made to go on in only one position. If all the holes don't line up, I think all you have to do is unbolt it and rotate it. If you rotate it on the the crank one bolt hole at a time, you should find one position where all the bolt holes will line up.
Chris
