Old 08-10-2004, 12:23 PM
wickedmach1 wickedmach1 is offline
Default Help with camshaft recommendations.
These are the camshaft specifications that both Comp Cams and Cam Research gave me for the engine combo listed below. Remember the car is for the street(70 Mach 1), maybe sometimes strip, and needs enough vacuum for power disk brakes. My max street RPM will be around 6000. Both will idle around 750 - 800 RPM. I am trying to reach my goal of about 480 - 500 HP. What do you guys think?
#1 Comp Cams = Hydraulic Roller Camshaft (duration @ .050" = 232/240 ; valve lift w/ 1.6 = 565/574, Valve Overlap = 65 deg, Lobe Sep = 110 deg w/ 4 deg advance, 12" Vacuum, Operating Range = 2200 - 6200 RPM (Small Base Circle Cam)
#2 Comp Cams = Hydraulic Roller Camshaft (duration @ .050" = 224/232 ; valve lift w/ 1.6 = 555/565, Valve Overlap = 57 deg, Lobe Sep = 110 deg w/ 4 deg advance, 14 -15" Vacuum, Operating Range = 1800 - 5800 RPM (Small Base Circle Cam)
#3 Cam Research = Hydraulic Roller Camshaft (duration @ .050" = 230/235 ; valve lift w/ 1.6 = 556/556, Valve Overlap = 14 deg, Lobe Sep = 110 deg, 15" Vacuum, Operating Range = 2200 - 4500 RPM (Standard Base Circle Cam)
393w Stroker bored .030" over
Scat Crankshaft 3.850 stroke
Scat H-Beam Rods 6.200 length
AFR 185 Cylinder Heads w/ upgraded springs
Weiand Stealth Intake Manifold
Street Demon 750 CFM Carburetor w/ mechanical secondaries
Comp Cams 1.6 ratio Pro Magnum Roller Rocker Arms
10.0:1 Compression Ratio w/ Forged Probe Pistons
1 3/4" Headers
MSD Ignition
Edelbrock Water Pump
T-5 G-Force Tranny
9" Rearend w/ 3.89 gears and locker
