Old 08-11-2004, 08:45 AM
Buzzmobile's Avatar
Buzzmobile Buzzmobile is offline
Cobra Make, Engine: SPF 148 with 427 SO
Turk, yes that sounds like the fuel pump I had. no name and chrome. I was just wondering about the summit carters...there are 3 to choose from and could use some help with which one I need. Part numbers CRT-M6905, CRT-M5905P, and CRT-M4539. These are the specific summit numbers for the 3 carter fuel pumps that they carry that will fit the FE. I know the variability is based on pressure and flow, but I don't know what I need as far as PSI and flow. Not a monster engine, just what I would consider a moderate FE. Moderate cam. 2X4 tunnel port. Can you have too much pressuer? Flow too much? My gut says go get the one that flows the most and has the most pressure....too much is never enought!.....BUT I know that is not always the case.
Lowell,
I will be looking into the fluid more here this week. Yes looks like more center origin. I have yet to really try and pin it down. I will be working on it this week and will keep you posted. I am not even sure I have a hydraulic clutch, I think it is cable. And I don't know about the the throw out bearing...haven't checked it out.
Guys, thanks for the advice. I will see what I come up with here and get back to you.
Buzz
