Low pressure spring - help needed
Guys I really need some help
I have rung a number of places in the US to try and get a Melling big block standard pressure relief spring as Milodon have stated they fit their pumps.
The story is I have purchased a Milodon 18770 pump which is a big block style pump that goes with the kicked out sump I have.
Unfortunately the pump came with a high pressure spring which I would prefer not to use.
Can any of you guys help and if any of you are dealers do you stock the Melling spring kit. I'm just after the big block standard rate spring, the one I took out is 2 7/10 in long.
I really would appreciate if you can help as it seems impossible to find a solution over here.
Thanks
Mike
Mikey B
