Thread: Electric Fans
Old 08-11-2004, 02:00 PM
SuperHart's Avatar
SuperHart SuperHart is offline
Cobra Make, Engine: Cobra Fibercraft Bodies 427 S/C, 351W disguised as a 427.
Send a message via AIM to SuperHart
I am running a 351W with dual quad intake. Up front is a 4 core vertical flow radiator for a 1969 429SCJ Mustang. In addition to the original style dual fans ahead of the radiator (for original appearance only) I run a SPAL 16" 2300 cfm puller fan mounted to the back of the radiator and an original FE expansion tank modified to fit the smallblock thermostat mount and a 180* thermostat. I have done a couple of parades on 90+ degree days and the radiator temp has not exceeded 190*. When the car is in motion, temp is usually 180* without the fans running. Hope this info helps.
Rupert Hartmann
Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
