Thread: FEs for Dummys
  #21 (permalink)
Old 08-11-2004, 09:51 PM
bmcmillan bmcmillan is offline
Cobra Make, Engine: B&B non-donor, 496 Genesis SO (608 HPwith 9.4:1 CR), Tremec TKO, Currier 8.8
JDOG,
One of the problems with 427's is that they are already bored out close to the maximum possible. When you need to bore a 427, you have to bore it in .003" increments, not the normal .010". I hate to tell you, but it is impossible to bore any Ford 427 cast iron block .030".
The stroker kit is a different story. A good way to stroke a 427 is to put in a 428 crank/pulley/flywheel in. A 428 crank stroke is .200" more than a 427 stroke.
Brian
