Thread: FEs for Dummys
  #22 (permalink)
Old 08-12-2004, 04:48 PM
Ibr8k4vetts's Avatar
Ibr8k4vetts Ibr8k4vetts is offline
Originally posted by bmcmillan
JDOG,
One of the problems with 427's is that they are already bored out close to the maximum possible. When you need to bore a 427, you have to bore it in .003" increments, not the normal .010". I hate to tell you, but it is impossible to bore any Ford 427 cast iron block .030".
The stroker kit is a different story. A good way to stroke a 427 is to put in a 428 crank/pulley/flywheel in. A 428 crank stroke is .200" more than a 427 stroke.
Brian
I disagree, I have seen 427 go .040 but you must sonic check it first!
Mike
