Old 08-13-2004, 11:19 AM
Flyin_Freddie's Avatar
Flyin_Freddie Flyin_Freddie is offline
Cobra Make, Engine: Superformance #770, Stroked 351W (393 cubes) w/ Tremec TKO-600, 3.27 Torsen locker, 'Hi-Tech' Blue w/ White Stripes, Wilwoods, Bilstein coil overs...and a big ear-to-ear grin!
Default Yo..Buzzster...
...check out the play in the clutch push rod. You should be able to wiggle the clutch push rod a little...should have some play in it. If not, then it's too long...possibly because the clutch has been misadjusted. There's actually three adjustment points in the clutch travel...the rod, the stroke length on the master cylinder, and then the pedal height in the driver's footwell.
If there's no play in the push rod from the slave cylinder to the clutch fork, then there could be constant pressure on the slave cylinder piston....which forces fluid around the seal, into the dust boot, and onto your garage floor eventually. (Ask me how I know this...go ahead!) Anyway, if you'll shorten the clutch push rod a little, this relieves this pressure and presto!...no more leak.
Check this out and let us know what you find. I'm thinkin' this is the source of your leak. Hope this helps...
Flyin_Freddie
"An opinion on everything...an expert at nothin'!"
WARNING: The opinions expressed herein do not necessarily represent those of the management, editors, or owners. We welcome differing opinions, and recognize our responsibility to offer differing views. May cause drowsiness, restlessness, or irritability. Do not operate heavy machinery while using this product. Void in Alaska, Hawaii, and Puerto Rico, or where prohibited, licensed, or regulated by law. We reserve the right to limit quantities. Offer good while supplies last. No substitutions allowed. Please observe posted speed limits. Professional driver on closed course. Do not try this at home. Please wear your seatbelt at all times. Close cover before striking. Use at own risk. Please dispose of properly. Drink responsibly. Prolonged exposure to vapors has been shown to cause cancer in laboratory animals. Do not use this product of you are pregnant, or plan on becoming pregnant. Intentional misuse by deliberately concentrating and inhaling fumes can be dangerous. Always wear safety glasses. In case of eye contact, flush with water and seek immediate medical attention. For occasional use only as directed. Avoid prolonged skin contact. Discontinue use if rash develops. If symptoms persist for more than three days, seek professional medical attention. Hearing protection required beyond this point. Danger: Hot surfaces. Use as directed. Proceed at own risk. Caution: Filling may be hot. Please don't litter. Actual results may vary. It is a violation of Federal Law to use this product in a manner other than as intended. Do not use this product if you have an enlarged prostate, or have difficulty urinating.
