Thread: E brake handle
Old 08-13-2004, 12:39 PM
goaztecs's Avatar
goaztecs goaztecs is offline
Cobra Make, Engine: LA Exotics (B&B) Cobra, 408W, Roush Heads, Demon Carb, Comp Cam, Tremec Z-Spec T5, 9" Auburn Rear
It is from a Mustang II. But I thought it looked ugly. What I did was I disassembled the e-Brake handle assembly, which requires a carbon bit for drilling out the two large rivets. I then pried the bonded epoxy "wooden" handle off of the lever. I sent the lever out to the chrome shop - and it came back PERFECT. It looks absolutely awesome. I then used hardened pins with cotter pins (originally intended for use in a garage door opener) to replace the two rivets that I drilled out, and then reassembled the assembly - very easy.
Bolts right back in, and looks great.
Check out the Bay Area Cobra Club Website at http://www.bayareacobraclub.com
