Too Big for Me
I installed the 870 on my 514 in a West Coast also. This was not the crate engine. I built it from the Ford Racing short block. Bottom line was it ran WAY to rich. I took the carb to a local carb expert who strongly suggested I downsize to the 770 CFM, which I did. Runs much better and have lost the obvious rich running. Haven't tweaked it yet. The theory is for street use, the smaller venturis provide higher air/fuel velocity that improves torque. The large CFM carbs are better for racing. His opinion, your mileage may vary.
One "problem" with tuning the Street Avenger carbs is they do not have replaceable air bleeds. You can change the jets, etc. but not the air bleeds.
The car is down now to replace the throwout bearing, but should be back on the road this week. Later this month I expect to have the 770 tweaked in. If I learn anything in the process, I'll share.
How do you like your new WCC?
Cheers!
Chuck
