Thread: Need Help!
Old 08-15-2004, 04:24 PM
goaztecs's Avatar
goaztecs goaztecs is offline
Cobra Make, Engine: LA Exotics (B&B) Cobra, 408W, Roush Heads, Demon Carb, Comp Cam, Tremec Z-Spec T5, 9" Auburn Rear
go big,
Unfortunatelty, my gas gauge doesn't work. I bought the car complete, so I'm making my way through it to de-bug. I haven't got around to fixing this yet. My existing tank, which is a steel tank from an ('89?) Mustang, has two senders - an upper and a lower. Here is what I've figured out so far.
Gauge/Sender - Resistance
Empty - Ohms
Full - Ohms
Faria Gauge - Unverified
240
33
Ford 1(my upper sender)
73
10
Ford 2(mylower)
16
158
I have found that the bottom line is that neither sender is compatible with the unverified Faria Gauge spec.
If the Faria gauge is as above, the only reasonable solution that I can come up with is to:
Buy, modify, and install a Faria or Stewart-Warner “Universal” sender in the lower section of the tank.
Best cost estimate - $25 + tax + shipping for a Stewart-Warner (could not find price for Faria)
Will need to modify the sender to fit my tank depth (a feature of the sender) and mounting flange (not a feature of the sender).
Could be made to accurately send very close to “E” when tank is empty, and close to “F” when full.
Check out the Bay Area Cobra Club Website at http://www.bayareacobraclub.com
